FS: (2) Phantom 5.8 GHz Remote Controllers
Los Angeles, CA
We have two older Phantom 5.8GHz Remote Controllers that are new in box.
Letting these two units go at $89/each shipped with in the US.
These are RC's were often used with Phantom 2 setups running Lightbridge but also work for controlling non-HD gimbals (like Zenmuse NEX 7, GH3...) when you use Lightbridge to control the aircraft.
Referred to as DJI Lightbridge Part 14 5.8G TX & RX Combo or DJI 5.8 GHz Transmitter and Receiver Combo for Phantom 2 Quadcopter
UPC: 6958265107122
DJI Part Number: CP.AL.000020
The 5.8 GHz Transmitter and Receiver Combo for Phantom 2 Quadcopter from DJI is intended to replace the original transmitter and receiver pair included with the Phantom 2 so that the aircraft can use 2.4 GHz accessories such as Lightbridge without the risk of radio interference. It is the same system that comes with the Phantom 2 Vision and Phantom 2 Vision+ models.
The transmitter is the hand-held radio controller while the receiver is the air-end component that installs inside the aircraft and interfaces with the flight control system. Installation of the receiver requires opening the Phantom 2's body shell, and will involve soldering.
Allows you to use 2.4 GHz accessories such as Lightbridge without interfering with the control signal
tom sauter
