V02.06.06.00 firmware update
Anyone try this with the P4P? Supposed to fix overheating and bring back the ability to download maps off-line.
I flew a CS 7" HB with this version and my P4P on a 92°F day using Go4. Although I didn't try offline maps I had a good experience.
Also, I was happy that it fixed the jerky live feed in the official Amazon store CS version of Litchi.
Reactions: The Ghost
I updated and re-rooted yesterday, no problems. Offline maps worked like a charm, the area per map download is smaller than I thought, wish you were able to select larger areas at a time.
Is anybody else having to "Reboot" the CS after the FW update, I get a screen freeze/unresponding pretty much every flight
I've only had a couple flights on mine since the update but mine has been good.
Additionally I've encountered the a pop up message "Go 4 isn't responding" a couple of times since the new update and had to perform a reboot to clear the warning. I decided to do a CS reset (included reformatting SD card in CS) but I haven't been able to test the CS after the reset.
Yup thats what I get , where's the reset located at in the Menu , I'll try it.
Edit
I found it, does it roll back to the firmware that was installed in the factory ? It says "Factory data reset"
settings --> Backup & Reset --> Factory Data Reset
No. It keeps the latest CS update. It flushes out files that may be causing a conflict with the latest update.
Edit
I'm not going to be able to test my CS until the weekend. :(
OK thank you I'm doing it now ,as soon as it stops raining im gonna go try
Sweet! Let me know how it goes!
Thats not a cure it actually made it worse I had to reboot three times and it still didnt connect I then shut both the copter and RC down two times then it connected, it started raining so I wrapped it up
Wow! That really sucks! Sounds like we're going to have to wait for DJI to send out yet another update for the CS...
Lucas_rc_pilot
