- Joined
- Jul 11, 2016
- Messages
- 141
- Reaction score
- 38
- Age
- 69
Anyone try this with the P4P? Supposed to fix overheating and bring back the ability to download maps off-line.
I flew a CS 7" HB with this version and my P4P on a 92°F day using Go4. Although I didn't try offline maps I had a good experience.Anyone try this with the P4P? Supposed to fix overheating and bring back the ability to download maps off-line.
I've only had a couple flights on mine since the update but mine has been good.Is anybody else having to "Reboot" the CS after the FW update, I get a screen freeze/unresponding pretty much every flight
I had to reboot a couple of times. I have a standard P4 and had the Go4 app crash on me a couple of times...Is anybody else having to "Reboot" the CS after the FW update, I get a screen freeze/unresponding pretty much every flight
Yup for me it happens at start up or soon after...I had to reboot a couple of times. I have a standard P4 and had the Go4 app crash on me a couple of times...
Yup thats what I get , where's the reset located at in the Menu , I'll try it.Additionally I've encountered the a pop up message "Go 4 isn't responding" a couple of times since the new update and had to perform a reboot to clear the warning. I decided to do a CS reset (included reformatting SD card in CS) but I haven't been able to test the CS after the reset.
OK thank you I'm doing it now ,as soon as it stops raining im gonna go trysettings --> Backup & Reset --> Factory Data Reset
No. It keeps the latest CS update. It flushes out files that may be causing a conflict with the latest update.
I'm not going to be able to test my CS until the weekend.Yup thats what I get , where's the reset located at in the Menu , I'll try it.
Edit
I found it, does it roll back to the firmware that was installed in the factory ? It says "Factory data reset"
Sweet! Let me know how it goes!OK thank you I'm doing it now ,as soon as it stops raining im gonna go try
Thats not a cure it actually made it worse I had to reboot three times and it still didnt connect I then shut both the copter and RC down two times then it connected, it started raining so I wrapped it upI'm not going to be able to test my CS until the weekend.
Wow! That really sucks! Sounds like we're going to have to wait for DJI to send out yet another update for the CS...Thats not a cure it actually made it worse I had to reboot three times and it still didnt connect I then shut both the copter and RC down two times then it connected, it started raining so I wrapped it up
I'm gonna give it another try later, I'll post afterwardsWow! That really sucks! Sounds like we're going to have to wait for DJI to send out yet another update for the CS...
Cool... I would also recommend reformatting the SD cards in both the CS and the Phantom just to rule out any weird inconstancy from the previous firmware.I'm gonna give it another try later, I'll post afterwards
Yes I always reformat but I see no need to stick a card in the CS cause it doesn't record to it , I just use a card reader on the copters sd cardCool... I would also recommend reformatting the SD cards in both the CS and the Phantom just to rule out any weird inconstancy from the previous firmware.
