Upgrade for Phantom 2 V1 motor ?
You don't need to change the ESCs for either of those. Both look like drop-in replacements. It's not clear what's different about them aside from the different props you get (and the price).
Thanks cityzen, the different from spec is Air 350 have more trust for each motor compared with Anti Gravity MN2214 which i suspect will be more powerful with less flight time
Thrust depends upon the motor and the propellers. Each kit is measured with the props it comes with. They come with different props.
Thus you can't tell if the difference is due to the motors or to the props.
Oh yeah i was forgot to mention, i'm planning using 9" prop.
Im comparing T-Motor spec for thrust on MN2214 motor using T-Motor Anti Gravity 9*3 prop while on Air 350 is using T-Motor plastic 9545 prop. On 100% throttle Air 350 motors with plastic 9545 props provide more thrust and more rpm ( which i think more power but less in flight time, correct me if i were wrong ).
Scav8tor
