Hello guys,
First
BSullivan, I'll need more info to help you, the red lights sounds like something is loose or unhooked. Have you opened your bird? Hooked to computer at all? Let me know.
Next
ThePhantomPain.
I'm not familiar with DSLR receivers? What Tx are you using?
The wires look weird to me
As you can see this in picture, the ( red and blue arrows point to your ( receiver ) wires, and the correcsponding arrows are pointing to where they should hook up ( stock ) as that is your stock receiver. Plus your dslr receiver looks to only have 1 wire connected? This looks odd.
I've tried researching DSLR wiring diagrams, but not much to be found?
I recommend contacting DSLR to try to acquire a correct wiring diagram! Plus I can't see where all the wires are going to? There are a LOT of aftermarket wires and components, that are inside, and hard to tell where stuff is going, or where it is hooked to? More detailed pics might help!
J Dot
