It determines your altitude when you are under 30' I believe. The problem with flying over water is that the VPS has a hard time distinguishing ground level as water throws off the sensors.What does the VPS do / not do that has so many people wanting to disable it?
Is there still no option to turn off VPS on the Phantom 4?
I like being able to fly low by the water, but I don't trust the P4 with VPS enabled.
If you turn off obstacle avoidance will that turn off VPS?
Here's how I turned it off so I can strap a battery under thereAs far as I know of that we can't disable VPS whatsoever.
Latest litchi has vps disabled optionHere's how I turned it off so I can strap a battery under thereView attachment 58450
Black electric tape, then white!
Can't say on that one, but the option is there if anyone gets a chance to test. I've a feeling it'll set/clear a flag in the bird itself regardless of what app you then use to fly. If someone could test that theory too? Weather lousy here and so is work!Does it actually work tho?
