Turn off quad
Getting ready for first flight and I can not find out how you turn quad off after flight. You have flown quad and landed it I assume props are still spinning how do you then turn quad off??
Pull throttle stick all the way down and hold until phantom shuts off!
Option 2: ( try above first, as that is right way )
If all else fails, both sticks down and together ( same as takeoff ) be CAREFULL doing this way
As quad MAY roll back, forward or sideways, messing up propeller, unless you have prop guards )
( I had a hard landing once, phantom would not turn off, sticks down and together, worked, but phantom
Rolled on its side a bit destroying 1 prop! ) but all other times throttle stick DOWN until motors stop is the right way!
Take care, fly safe! Good luck!
Jerry D
USA
( J Dot )
jeetbuzz360
