Solid red LED
Guys, have read about this and says error, calibrate, get error 27 (seen here before) props did start but only had 5 GPS locks so did not fly. tried in a better area later had 8 GPS locks but still solid red LED so props wont start, now I did have a small crash 3 weeks ago but have flown ok since, any ideas?
After the crash did you re-calibrate the P2's IMU? If not do so and then re-calibrate the compass and you should be good to go.
Yes and just does again, now flies thanks but not able to lock into GPS but this app says count is low anyway for where I live http://www.uavforecast.com/ just done a 15 minute low level flight in effectively Atti mode and all seems well
My P2V+3.0 gets gps and flies just fine, but I have constat red front and constant green rear LEDs. Is this a IMU problem?
Thanks.
Solid Red fronts mean motor start. Continuous slow flash Green in rear indicate sufficient GPS sats. acquired.
There's no solid Green rear except after 1st half of compass calibration.
