Smart Phone
I can get a P3S with only 2hrs flying time on it for A$ 500.oo .The problem is that I have only an old smart phone (Galaxy 2s ) . My question is ,can I fly the P3 without the smart phone ? Cheers
Yes, you can fly without any device, without FPV doen't make it worth the price but yes you can.
Reactions: ravedog
So you only use the smart phone for FPV ?
That's it. But why even bother with such an aircraft that is so capable of much more. The camera is basically useless without FPV, but it will still fly.
I will offer a few notices of caution.....You will not be able to change any settings on the Aircraft without FPV. Primarily speaking of Auto Return to home. If these are set at the defaults, you will most likely crash. I would never even remotely attempt to fly without at least those settings done, you are asking for disaster.
The P3S is a good, solid performer and an affordable entry level drone. Having said that, I feel that $500 for a P3S is at the very high end of the price range, regardless of being next-to-new with only 2 hrs of flying. At their peak, they sold for $500 new, and Walmart had them on clearance for $399 not too long ago. For that kind of money, you could likely get a good used P3A or P3 Pro. As @Fly Dawg stated, you can fly a P3S without a phone or device but, without being able to see exactly where you are, or where you're going, or without getting any flight telemetry (altitude, speed, distance, etc.) you will have to fly it within a VERY limited visual range.
As for your Galaxy 2S, you could certainly try using it with the DJI Go app but, I doubt that the 2S would be able to support the app very well. It's been quite a while since I've seen a 2S but I'm quite certain that it's only a dual core processor being of that vintage, and probably not a very fast one. Available free memory may be a problem as well. I have an alternate recommendation to suggest. Try to negotiate a much better price for the P3S, or find a good used P3S for $300 - 350, and use the money you save to buy a newer phone with, say, a quad core processor and at least 16GB of memory to use for flying. Yeah, you can fly the phantom without a connected phone/device, but where's the fun (and safety) in that? Good luck with whichever way you go.
Maybe I give it a miss ,I am not very good of setting things up like that , I managed to set up my P2 , that was difficult enough :) ,thanks
Oh, yeah, I'm assuming that you got the seller to document for you that the Phantom only has two hours on it, and you didn't just take his word for it.
yes he's got it recorded ,also it is $500 australian money plus 2 batterys ,the p3 sells for about $600 upwards ,cheers
My question is ,can I fly the P3 without the smart phone?
While possible, the aircraft will be limited to a height of 30 meters and distance of 50 meters if firmware 1.9.20 is installed on the aircraft.
SIvanka
