- Joined
- Jul 20, 2017
- Messages
- 15
- Reaction score
- 1
- Age
- 36
Dear Pilots,
I am selling my partly totally new partly refurbished >DJI PHANTOM 2 + H4-3D Gimbal + FPV Kit with LCD Screen<.
You can buy it directly via eBay. If you are out of EU we need to agree on terms of shipment.
The Auktion is here:
Here the Specs:
• Ready to Fly, Multifunctional Quad-rotor System
• Customized H3-2D and H3-3D Gimbal Support
• Precision Flight and Stable Hovering
• 25min Flight Time & Smart Battery
• Auto Return-to-Home & Landing
• Advanced Power Management
• Intelligent Orientation Control (IOC)
• Easy Battery Replacement
• Self-tightening Propeller
• Video Downlink Support
• CAN-Bus Expansion Module
AIRCRAFT
Weight (Battery & Propellers included) 1000g
Hover Accuracy (Ready to Fly) Vertical: 0.8m;
Horizontal: 2.5m
Max Yaw Angular Velocity 200°/s
Max Tilt Angle 35°
Max Ascent / Descent Speed Ascent: 6m/s; Descent: 2m/s
Max Flight Speed 15m/s(Not Recommended)
Diagonal Length 350mm
Flight Time 25mins
Take-off Weight ≤1300g
Operating Temperature -10°C ~ 50°C
Supported Battery DJI Smart Battery
2.4GHZ REMOTE CONTROL
Operating Frequency 2.4GHz ISM
Communication Distance (open area) 1000m
Receiver Sensitivity (1%PER) -97dBm
Working Current/Voltage 120 [email protected]
Built-in LiPo Battery Working Current/Capacity
DJI SMART BATTERY
Type 3S LiPo
Capacity 5200mAh, 11.1V
Charging Environment Range 0℃ to 40℃
Discharging Environment Range -20℃ to 50℃
Technical specs of the FPV Kit:
1 x Boscam 5.8G 600mW 32 Channel Wireless AV Transmitter with all cable
1 x Boscam 5.8G 32 Channels wireless AV receiver with all cable
1 x 800x480 HD Monitor with sunshade
1 x power cable
1 x FPV cable suit for Gopro or SJ4000 SJ5000 SJ6000
2 x English Manual
Functions:
• 32 channels: Cover A, B, E bands and F bands
• Two switching buttons for the band and channel
• Two digits display for the band and channel
• Power off memory for last channel and band
• dual Independent video and audio signal outputs
Specs:
Video format supported: NTSC/PAL
Antenna connection: RP-SMA, jack (module side, both TX and RX)
Transmitter TX TS832 specs:
Power input: 7.4-16V (3S Lipoly suggested)
Transmitting power: 600mW
Antenna gain: 2dbm
Working current: 220mA at 12V
Video bandwidth: 8Mhz
Audio bandwidth : 6.5Mhz
Weight: 21g
Dimension: 54x 32x 10mm(excluding antenna)
Receiver RX RC832 specs:
Power input: 12V
Working current: 200mA max
Antenna impedance: 50Ω
Antenna gain: 2db
Rx sensitivity -90dBm
Video impedance: 75Ω
Video format: NTSC/PAL auto
Dimension: 80x 65 x15mm
Weight: 85g
Frequency range:
FR1 5865,5845,5825,5805,5785,5765,5745,5725
FR2 5733,5752,5771,5790,5809,5828,5847,5866
FR3 5707,5685,5665,5645,5885,5905,5925,5945
FR4 5740,5760,5780,5800,5820,5840,5860,5880
800x480 HD Monitor with sunshade description:
Panel Size: 7.0 inch
Panel Type: TFT LCD
Resolution: 800x480
Backlight: LED
Horizontal Frequency Range: 30~60kHz
Field Frequency Range: 50~75Hz
Dot Pitch: 0.0642 (W) x 0.1790 (H) mm
Display Ratio: 16:9
Brightness: 400 cd/m⊃2;
Contrast Ratio: 500:1
Response Time: 15ms
Viewing Angle: 70°/70° (L/R) 50°/60° (U/D)
Input Voltage: DC 6~18V
Power Consumption: ≤ 5W
Working Temperature: -20°C ~ 60°C
Storage Temperature: -30°C ~ 70°C
Dimensions: 182 x 127 x 32mm
Weight: 363g
Here the Specs:
- H4-3D Zenmuse (boxed as new) - ca 239,00 € at Idealo
- Smart Flight battery (boxed as new) - ca. 108,99 € bei Amazon
- Completely new Casing of the drone - no scratches etc.
- 5,8Ghz FPV Kit inkl Display NEW as boxed ca. 150€
- Controller NEW as Boxed
- Charger with divers adapters (no adapter for EU)
- 6 Propeller
- Manual
- Documents proving the refurbishement/new shippment
- DJI Tools + Stickers
AIRCRAFT
Horizontal: 2.5m
Max Tilt Angle 35°
Flight Time 25mins
DJI SMART BATTERY
Type 3S LiPo
1 x power cable
2 x English Manual
Functions:
Specs:
Antenna gain: 2dbm
Weight: 21g
Power input: 12V
Antenna gain: 2db
Weight: 85g
Frequency range:
Panel Type: TFT LCD
Resolution: 800x480
Backlight: LED
Display Ratio: 16:9
Response Time: 15ms
Weight: 363g
