run away
Not that I know of. I did tear it down to replace the 3 in one. Don't remember if I had to unplug or deal with the gps.
I am getting the error "Bring the sticks to center and continue" with two different drones. And I'm not touching the sticks???
You had marginal GPS (with only 8-9 sats) for the early part of the flight, but this dropped to less than satisfactory from 1:59.4 until 7:32.9, which left your drone in atti mode.
Without GPS, the drone loses the ability to hold position and can drift with any wind.
It would still have been controllable, but you didn't do much to stop it being blown away.
The reason for the poor GPS sat numbers isn't clear.
In that area and at the height you flew there shouldn't have been any problem.
It should have been picking up 15 sats or more rather than 6-10.
Is there any metallic sticker on the top of the drone's shell?
Try flying somewhere a few miles away, in a large, open area and keep an eye on the sat numbers.
If it's low again, there may be a problem with the GPS receiver.
If you look at the flight log you will see that at 3min21.3 the distance from home was 12.7.
At 3min21.7 it was 450 feet from home. That is 383 feet in .5 seconds.
From 1:59.4, your GPS reliability dropped to 0/5.
The GPS receiver was still giving some data, but the flight controller recognised that it was unreliable.
With false position data, you also get false speed data.
Looks as if once GPS gets dropped even if more satellites are picked up the drone ignores them.
The flight controller is constantly looking at the GPS data and if while it is unreliable, the drone will not go back into P-GPS Mode.
GPS quality depends on more than just the number of satellites.
I just replaced the GPS module and antenna. Still getting "gps weak signal". Outside, I get 10 satellites and a few bars then no bars and 3 or 4 satellite.
Replaced total top with one from a working drone. Getting same error.
Any ideas?
Any ideas?
Bad connection between the GPS and mainboard?
I replaced the fully functional top shell minus the 3 in 1 board. Had to use the one from the original top half. At the time replaced all flat ribbon cables. That should eliminate the path from gps through power distribution board to 3 in one. Could it be the 3 in one?
Replaced 3 in 1 board. That fixed the problem.
The problem is firmware 01.05.600, I fix drones in Ecuador and I have 3 drones with the same fault "braking now. Return sticks..." when changing the 3in1 card the problem is fixed but if it is with the previous firmware, does anyone know how to reset the 3in1 card or downgrade the firmware?
El problema es el firmware 01.05.600, arreglo drones en Ecuador y tengo 3 drones con la misma falla "braking now. Return sticks..." al cambiar la tarjeta 3en1 se arregla el problema pero si esta con el firmware anterior, alguien sabe como resetear la tarjeta 3en1 o hacer downgrade del firmware'
:Thanks for your input. I will look into the GPS problem. My other drones get more satellites in the garage than this one out in the open.
I haven't ruled out the problem with the remote sticks. When it went AWOL by the time I could see the direction it went it was out of sight. We did have some wind that day but it wasn't in the direction the drone took. If you look at the flight path it looks as if it was a straight line, not just drifting with the wind. This is the first event like this so I will look into both before flying it again.
Thanks.
haha lol
Arcadia JC
