RTH
Hi
I have just purchased a P3 and since I did the firmware update the RTH function no longer seems to work. I cannot a "home" fix despite receiving 16 satellites it comes up with "Mobile device GPS signal is weak and its location cannot be acquired", but vocally I am told "The home point has been updated, please check it on the map"
Pushing the RTH button results in the machine landing where it is.
I took it back to the distributor here in France and they say that is is OK. Having done 500 miles for nothing I would appreciate some help or advice.
Do you see the home point marked on the map? Was your Phantom more than 20m away from the home point when you initiated RTH?
It sounds as though you are trying to set the home point as the controller, instead of the P3.
In the app tap on the H symbol and make sure you then select the arrow, not the person.
You are wonderful thank you so much I was too close to home i.e. less than 20m
Anyway my drive across France was very pleasant. Where do you find out these limitations?
thedrinklabsus
