RTH saves me $680
If you turn on your transmitter whilst in the go home mode with the Phantom will just continue with the go home procedure you either need to let it land or you can switch to ATT mode and take back over the Phantom. You need to remember that if you turn your transmitter off to activate the go home it takes at least 3 seconds.
This is a really shaky video of me recording the go home on my phone from the moment the video starts the Phantom is flying itself also the sun was behind me so I couldn't actually see my phone screen so I was recording it blind lol
http://youtu.be/qkxvlFkd0t4
Brian
yappy said:
Hello all.
I'm new to the forum and new to quads really.
I've been flying my phantom and loving it so far, I can still easily loose orientation. Still learning how to fly with the rear of it not facing me etc..
Question:
If I turn off the transmitter purposely during flight in GPS mode, the phantom should fly back home right. While it is flying back home, what happens if I turn back on the transmitter?
I am very curious to test out RTH feature, but turning off the transmitter feels scary. hehe :lol:
ptjackson said:
I had an unintentional test of RTH yesterday. I was practicing in ATTI mode and it was a little windy. All was well until I was about to hit a small tree and I've taught myself that up is my "panic" move. So that worked fine I missed the tree but the wind caught it and blew toward other trees. So I went up again. By this time the wind was carrying away my Phantom and it was pretty far away and I was getting worried. Best I remember then I switched to IOC homelock (not remembering to switch to GPS) and pulled back on the stick. To my shock it appears the phantom is moving AWAY from me close to out of sight. I put in Course lock mode and pull the stick toward me but for some reason it still doesn't appear that it's coming back. At this point it's almost completely out of sight. Finally I just turn off the transmitter and hope for the best, nothing...
I go in the house to get the keys to the car thinking I'll go look for it but knowing I live in a rural area it's probably gone forever. It takes me a couple of min to find my keys and walk outside when I hear bzzzzzzzzzzz I look up and to my amazement there is the phantom doing what it should do. It hovered high above my head and then landed itself within 2 feet of it's take off point. Perfect.
Lessons I learned.
1. glad I had made sure that home lock worked before aggressive flying. I took 2 min to test all that before beginning flying.
2. Glad my "panic" move is to go higher as if the phantom would have been lower there's no way it would have RTM as there are too many trees and power lines at low altitudes.
3. Don't practice atti mode on windy days as the quad can get away from you pretty quick
4. Probably best in a panic situation to take 3 seconds and stop and look at your controller, if I had, I would have realized I had never switched back to GPS mode and this home lock wasn't going to work
5. Glad I have a RTM feature for newbies like me.
did you hook up to NAZA assistant and activate IOC?
jeetbuzz360
