Well, about 20%. If EVERYTHING had to be 100% "on topic" what fun would any forum be?DKDarkness said:5000 replys in this thread! How many are relevant...? ;-)
ciguli said:Does anyone know when the updated 3rd axis version is coming out?
jjwalkers said:ciguli said:Does anyone know when the updated 3rd axis version is coming out?
You need to ask keri.
jjwalkers said:Ok, I have a question
I have the PT2 assistant installed on my Mac. The instructions for the Gimbal say to go to advanced and under gimbal enter 0 for the pitch hit enter then in servo enter 450. My assistant software doesn't have those settings. I looked at a youtube video on how to install the gimbal and saw that he was using something called Naza-M assistant. Can someone please explain what I may be doing wrong and should I be using it. For information I didn't attach the PV2 while doing this. Maybe the assistance changes if I did, I don't know. I thought I would ask before proceeding.
John
gunslinger said:Finally have my RotorPixel and it's mounted and seems to work well. Those of you with a hard case. How much surgery did you have to do to the case and how's it working out? Does this thing travel well without having to lock it down somehow?
Thanks...
-slinger
Soleangel said:jjwalkers said:Ok, I have a question
John
Sup man.
You need to switch to NAZA M on the assistant itself.
On the top of the software click where it says "NAZA M" that means you're switching the mode to fly in the NAZA.
But please do your research before you switch because you might trigger something you don't know and may cause damage.
