I have watched a number of YouTube videos, and searched numerous threads on this topic, but no answer.
I am going to shoot sailboats from a moving boat in the Pacific Ocean, and I need the Phantom 4 Pro set to RETURN TO THE CONTROLLER, not home point.
I understand the concept. You open the Home Point Settings and see two icons. One is an arrowhead and a dot, the other icon is a person and a dot. If I click the arrowhead, the drone sets a home point when it takes off and returns to that in an emergency.
I set it to "Set your current position as the Home Point" and tested this in a park today. When commanded to return home, the drone dropped straight down at its current location and landed, nowhere near where I was with the controller.
This is of no use for me out in the ocean. If I lose the drone and have it just go straight down (into the the water) and land.
Is the "Set Your Current Position As Home Point" supposed to set the drone straight down? Or is that supposed to send it back to the controller? I can't figure out what I'm doing wrong.
Shouldn't there be a setting that says RETURN TO CONTROLLER???
Can someone give me instructions to have the drone FLY BACK TO THE LOCATION OF THE CONTROLLER?
Thank you so much.
**** Allgire
Honolulu
Thank you so much.
**** Allgire
Honolulu
