Sounds like you are using an Android device? The last I heard, the device name change option is only available in the iOS version of the app.cant figure out how to change the device name also its a P34K I watched a video on the tube but my DJI go doesn't have device name listed anywhere to be changed not sure if that feature is only available on the higher priced birds
ah ok if I use an iOS to change it will it keep it in android ? I can use my daughters device to do the change overSounds like you are using an Android device? The last I heard, the device name change option is only available in the iOS version of the app.
Hi p34k only comes up on list once ac and rc conected then click std and wifi will bring up p34kyeah I've been flying it just wanted it registered to me cant figure out how to change the device name also its a P34K I watched a video on the tube but my DJI go doesn't have device name listed anywhere to be changed not sure if that feature is only available on the higher priced birds
Yes, that is exactly how Android users do the device name change.ah ok if I use an iOS to change it will it keep it in android ? I can use my daughters device to do the change over
You have to sign out of app and relog in with your email address,??????.???is it possible to re register a drone I bought second hand with DJI
I am flying the bird under phantom 3 4k it auto connects because I power the RC then the AC then open the app and the phantom 3 4k is already on the screen I just click connect and go flying. That isn't the issue I had the drone works perfectly fine so does the app I just wanted to know if I can re register a drone that I bought second hand as in used already registered by the guy I bought it from.Hi p34k only comes up on list once ac and rc conected then click std and wifi will bring up p34k
Thanks Brother Ill do it on my daughters iOSYes, that is exactly how Android users do the device name change.
DJI automatically knows from the GO app. It keeps track of every move you make. Just login and fly.is it possible to re register a drone I bought second hand with DJI
Yeah would still like to have it registered by serial number under my name I can live without that though and I plan of buying the P3P so the 4k will be a back up. I bought the 4K second hand and had to replace the motors because the first owner put super long screws through prop guards and Damaged the motors. This is why I usually always buy brand new. I got it for a reasonable price so I took a chance on it. Ill buy the P3P new same as I did the P3SDJI automatically knows from the GO app. It keeps track of every move you make. Just login and fly.
They have the serial number they can see your the one flying it and the old owner is not flying it. I own a used p3a and dji said they could automatically tell by usauge who owns the drone. They consider possesion and who is currently flying a given serial number. So if you call DJI tech support will know that's the Drone you've been flyingYeah would still like to have it registered by serial number under my name I can live without that though and I plan of buying the P3P so the 4k will be a back up. I bought the 4K second hand and had to replace the motors because the first owner put super long screws through prop guards and Damaged the motors. This is why I usually always buy brand new. I got it for a reasonable price so I took a chance on it. Ill buy the P3P new same as I did the P3S
They should only have that information if you're syncing your flight logs in DJI GO. Otherwise, they likely have no idea what is going on locally.They have the serial number they can see your the one flying it and the old owner is not flying it.
