Remove flight controller from main board (Phantom 2)
Hoping someone can give me some tips on removing the flight controller from the adhesive on the main board.
I apologize if this has been covered before, I searched and saw a lot of posts talking about FC replacement, but nothing about to actually safely remove it!
Thanks for reading!
Thanks for reading!
You should be able pry it off the board as it is only held down with double-back tape.
Appreciate the response. I knew it was just double-sided stick tape that was holding it on, but I was flexing the PCB a little too much for my own comfort!
For those who care or stumble upon this post, I wound up using a small, plastic pry tool and working around the edges until I could slowly lift one side. I just kept pressure applied and it eventually gave in and came off.
Cheers!
jorge sanchez
