Recovery from Failsafe.
I'm a newbie so be kind. Knowing that turning off the Tx to trigger Failsafe can be fraught with potential problems, I set my modes to GPS, ATTI, and Failsafe so I can trigger Failsafe from the mode switch and not have to turn off the Tx. But now I'm confused as to how to recover. If for some reason I want to trigger Failsafe by using the mode switch, do I simply swtch my mode to ATTI (my Tx is on since I never switched it off)? This would be similar to the method described in the NAZA quick guide as when in ATTI and you have a weak signal and the signal is later regained.
Yes just switch it off from Failsafe back to ATTi if that's the mode you had it in, Not sure if switching it to GPS will work the same as I have switched it to failsafe but for some reason believe that I put it on GPS and gained back control!
Don't quot me on that though because I'm not a 100 percent sure because it happened awhile back.
axipap
