propeller balancing
another question, Ive been looking at propeller balancing equipment, dubro and ocday a little confused on which one will work with p4p propellers. I know it needs to have a 3mm rod, but on which unit and model I need I cant figure out. I'm still pretty new to this and from reading the forum Ive learned a lot from you all. thanks for any information you can give me.
Thanks just did sounds like there might be an operation issue, from posts confirmed the 3mm rod. Thanks
Reactions: RémyHeli
I have a list of commonly used prop balancers and rods here.
I first used a a mechanical pencil that fit the hole in the hub. It worked perfectly. All DJI props I had were perfectly balanced. A set of carbon fiber ones were OOB with half of them out. I then ordered a ??? brand and repeated the tests with identical results. In short if you use real DJI props you don't need to check them!
Jim
WA5TEF
Reactions: RémyHeli
Aeria
