Well I might have to try and make this compatible with my mount.
Is there anyone who can weigh the 3D printed version?
SlackerATX said:I wish I had know about this before I got my taco. Cool project. But as far as I know the controller with the gimbal is the same. Is that right anyone know?
I haven't been able to get a simple question out of my head. Why do we even need an external controller? Does the stock servo used for tilt have a controller or is it controlled by the naza-m? Why can't we connect two new servos directly to the stock phantom? The assistant software has options to change tilt and pitch so it leads me to believe the hardware is already there.
The only thing that makes me think this isn't possible is if the stock servo mounted externally is more than just a servo. It's a controller as well.
teji said:Hello.
Here is my proto for 3 axis gimbal for P2V.
It work fine at ground but some vibration problem in flight.
Please remember .... its a first proto. Lego lending gear just used to test ! ;-)
I propose again to collaborate with every people wanting a free and open design for everybody.
Already printing corrected parts to reduce vibration in flight.
Very exiting.
News will follow
Nice.....
teji said:Hello.
Very exiting.
News will follow
do you have an open source for the gimbal.... can you make the files available so I can print. What controller are you using?teji said:Here is First test about my 3 axis home made open source gimbal on my P2V
Please note, it's a proto ! only a proto ! This is his second day of life, and second flight ! ;-)
No settings yet !
the gimbal continue to vibrate, i have to eliminate theses vibrations.
but 3 axis stabilisation work fine. Has to fine tune P.I.D. settings & 7th channel to pich channels.
https://vimeo.com/90101621
Ballad said:Soon I have all my parts to build the gimbal. DK, how did you attached the camera? Is it ony M5 plastic screws in to the camera holes, if so is that enough?
Using alexmos 2d+extension board with so 2.4b5.AllanVB said:do you have an open source for the gimbal.... can you make the files available so I can print. What controller are you using?teji said:Here is First test about my 3 axis home made open source gimbal on my P2V
No settings yet !
Thanks
Great Job
My gimbal is printed and waiting for my controller. What motors are you using? Can you send my a profile settings. Thanksteji said:Using alexmos 2d+extension board with so 2.4b5.AllanVB said:do you have an open source for the gimbal.... can you make the files available so I can print. What controller are you using?teji said:Here is First test about my 3 axis home made open source gimbal on my P2V
No settings yet !
Thanks
Great Job
Send me your mail via MP, I can provide you details
jiannelli said:Never 3d printed something. Where in the states can I get this printed? East coast preferred.....
Is this design available for downloading to 3d print? ThanksDKDarkness said:Got myself a 3D printer, got sidetracked
Example: http://www.thingiverse.com/thing:356168
Just to let people know, it is an ongoing project, and you all better buy a 3D printer, 'cause it is the next big thing ;-)
Decided I wanted to print the gimbal instead of handcrafting it out of aluminium:
DKDarkness said:A little status update:
This is what it looks like, when I do my testing: http://youtu.be/ApPEFi2EdyM
The most recent files for 3D printing can be found here: http://www.thingiverse.com/thing:363690
