I just added support for GoPro Hero 3(+) to the MotorPixie Gimbal. Find it at Thingiversehttp://www.thingiverse.com/thing:363690.
You are the MAN. I am printing out right now and will assemble this week. What settings are you using with your controller. Can you post a profile or send.DKDarkness said:DKDarkness said:A little status update:
This is what it looks like, when I do my testing: http://youtu.be/ApPEFi2EdyM
The most recent files for 3D printing can be found here: http://www.thingiverse.com/thing:363690
Please note that the design: http://www.thingiverse.com/thing:363690 has changed:New versions 22/6/2014:
* Updated FC200 enclosure to make adjusting balance point easier
* Updated pitch arm to make adjusting balance point easier and there is now clearance 360.
* Updated baseplate to accommodate 360 clearance and nicer cabling.
* Updated BaseCam case to make board fit within confines of box. Easier access to cables. Reduced height by 1mm.
Note: IMU box is subject to change.
ProfessorStein said:This looks nice!
So has anybody printed these by a commercial third party printer? Would love to know how much they might charge. I don't even know... are there shops that print at higher or lower "resolution"? Any pointers?
And what material are you folks printing in... what's the right balance between strength and weight?
AllanVB said:You are the MAN. I am printing out right now and will assemble this week. What settings are you using with your controller. Can you post a profile or send.
Appreciate all your help and time.
Allan
Thanks....DKDarkness said:AllanVB said:You are the MAN. I am printing out right now and will assemble this week. What settings are you using with your controller. Can you post a profile or send.
Allan
Since Profiles vary depending on firmware, I can give you the values, find them here: https://sites.google.com/site/motorpixiegimbals/support
ProfessorStein said:So I've never torn apart, let alone built a gimbal before... but this is getting really intriguing and I'm just about willing to try.
DKDarkness... earlier you said you were spec'ing the print to utilize the Alexmos 2D controller + extension board. But... isn't the extension board to add 3D?? Confused why you would need the extension board if the MotorPixie is 2D. Or am I thinking of something else entirely?
EDIT: nevermind about the parts list/motor specs... found them on the website.
robby666111 said:Hi,
Is there any chance you can add in a stp or iges of the model?
I use solidworks so might tweak/personalise the parts. So if you are able to supply solidworks parts/assemblies that would be even more awesome!
Also I remember seeing a wiring diagram somewhere, but can't seem to locate it. Are you able to re-post?
Edit - Found it on your website! https://sites.google.com/site/motorpixi ... /Resources
Cheers
Rob.
PS. Happy if you want to keep the source protected and not release these...
