Problems with P3 Pro 1080p 60fps?
I set the video on my Phantom 3 Professional to 1080p 60fps (1080/60) to be compatible with my iPhone and iPad. Every now and again, the video file is corrupt and can't be played even after re-inserting the memory card back into the drone and re-powering the drone (to allow the drone to fix a corrupt video file during power up).
Is anyone else seeing this?
Is it possible the drone can't handle 1080/60?
***thanks***
***thanks***
What's the error you get?
Your P3P can handle 1080/60
Yes I upgraded to a faster card
How fast?
Class 4 to 6??
Try using the 16G lexmark that came with the P3.
You need a UH1 or better. 1080p @ 60fps is 40mbs. 4k @ 30fps is 60mbs. You need a card that meets those minimum requirements.
Also check if your card is legit. Android has an app called SD Insight. It checks validity of card manufacturers.
I had a generic, no name, 64gb UH1 card.
I upgraded to a Sandisk Extreme 64gb UH3. I don't have enough experience with the new card yet to say if that has solved the problem, but I expect it will.
Your Apple products don't run at 60fps. They run potentially at 60fps, but always at a variable frame rate.
robvalduga
