- Joined
- Jul 7, 2016
- Messages
- 6
- Reaction score
- 0
- Age
- 32
someone can help me ?
Put something under the landing gear so the camera is not hitting the table and also connect the USB to the camera to see if it is getting power. Have you calibrated X1 in both the controller and P2 software?
Take and post another video after you've raised the P2 up off the table.
Thank you. How can I calibrate X1 in both the controller?
yes, I downloaded all the software. I run everything as you wrote but has not solved anything . Here's the video
I resolved, I had to calibrate x1 . Thank you very much!! You were great !!There is a screw on the shaft under the yaw motor as in this photo make sure it's tight.
Dose the camera stay where you last adjust it or return to the position as in you video.
Hello Jason, today the problem has come back . A screw it 's tight and I don't know what is the problem
Your tilt motor/potentiometer is damaged.
Judging by your previous post with the video, the tilt is stuttering when you are tilting up and down.
