I picked up a Polar Pro Gimbal GUARD to put on my Phantom 3 Standard.The camera lens hits the guard when tilted down..Anyone know how to fix this..I was thinking of grinding a little off where it's hitting with a dremel tool..Any thoughts....
It may not be on properly try turning it 180 degrees , I had taken mine off and when I put it back on I was having the same problem, turned it 180 degrees and problem solved.
