- Joined
- Jan 8, 2016
- Messages
- 139
- Reaction score
- 38
- Age
- 59
Very interesting Nix, what equipment did you test with?
An infrared thermometer
maybe hook all together then start the chargeWhen I plug in the modified dji battery to charge it blinks the green lights to show it's charging. When I hook the other two batteries up to it, charging lights on the smart battery go out as though it's not charging. What gives?
Well, this just arrived! Don't think I'll get a chance to fly it this weekend. Looking forward to this though. I'm really surprised how heavy the splits are! That's a lot of extra weight that I guess the extra juice makes up for. This should be very interesting to see how it goes!
Weight is 449G,....then what is the weight of just the smart battery by itself?
The modified P3 smart battery is about 377G
If you just leave them plugged in they should charge on the way, you may have to turn the battery on first then plug the externals in, you know it takes 2 1/2 times as long to charge it all together than it does just a normal smart batteryActually no, the splits only shows half full. Not sure what to do now as the smart battery is fully charged now. I have them hooked up thinking they'll charge anyway?
I have a prodigy 680. It doesn't have that choice of battery. Crap.If you charge these splits w/out the smart bat using a independant charger you should charge them on the liHV setting 15.2 v so the end balances are 3.33-3.35
You can plug the smart battery into the DJI charger and let it start charging them plug your split into your prodigy and let it charge up to 4.20 then when it's all done just plug it into the smart battery and let it top off, I've done that to speed things up a littleI have a prodigy 680. It doesn't have that choice of battery. Crap.
Hey Frank, I played around for an hour trying to sync I-phone to I-tunes did out txt file etc.Hey Mike would you care to share your .txt flight log file to that run? If so you can attach it here the same as a image. Or send it to me in a PM if you prefer.
Btw, do you know the red flag limit on battery volts, and also what happens now with the P3 when that limit is reached?
