Please help... No gps just blinking yellow light
Ok .. Got it . so basically i am only checking to see if the wires are ok at this point correct? Any good way to check the board it self?
Understood.. Again thanks for all the help and time.. I will be checking it all again over the next couple days..
And you can check if the gps board get power ( voltage )
put needles beside the wires and check with the voltmeter or there is power
I got this result
red - brown 5.50 volt
red - yellow 1 2.47 volt
red - yellow 2 2.35 volt
yellow 1 - yellow 2 0.11 volt
yellow 1 - brown 3.04 volt
yellow 2 - brown 3.15 volt
Watch out that you do not cause a short circuit between the needles or you wil fry the naza or/and gps
Utica
