Hi, I am writing here hoping that someone who has experience repairing phantom drones could give me an advice:
I had crashed a phantom 4 pro drone and it is quite damaged:
- one of the drone arm bent so at least the upper shell should be replaced
- both skid landing suports are broken and dettatched from the drone so new replacement for the landing suport is necesary
- camera rippen of and dettatched from the drone so yaw arm replacement and wire replacement necesary
- one of the proppeller motors is stuck (cannot be freely spin by hand more than 1 or 2 degree angle) so new motor for replacemet needed
In order to save the situation, I found on sale another damaged drone this time a phantom 4 pro V2 drone wich has no camera (was rippen of during the impact with a building and coudn`t be found). This drone has the landing suports in good shape, the shell is not bent, and look as a good one to put the camera from my phantom 4 pro drone and to have a good functioning drone.
The only concern with the phantom 4 pro V2 drone is that at start it shows ESC error instead GPS signal ok
Also, when you try to start it, only 2 of the 4 motors spin and on the display shows the error: " Takeoff error. Check the motors and propellers"
You can see a videoclip with tis phantom 4 pro V 2 here:
Can I take parts from my phantom 4 pro and replace on phantom 4 pro V2 to make a good fliyng drone ? I mean propeller motors, the camera. Are these spares compatible between these 2 drones ? (I know that the remote controls are not interchangable, but this is not an isue as the seller stil has the remote controll)
I attached photos with my phantom 4 pro damaged drone
Thank you in advance for your answers.
