- Joined
- Nov 2, 2016
- Messages
- 8
- Reaction score
- 2
- Age
- 44
Can you do this battery mod on any p3?sure you can
Yes you can, here's an FAQ I wrote Battery Modification for DJI Phantom 3 FAQCan you do this battery mod on any p3?
How long does it last?
Can you tell more info about it with details?
Thanks
ThanksYes you can, here's an FAQ I wrote Battery Modification for DJI Phantom 3 FAQ
I just got back from holiday, hoping to get back into this conversion in a day or two, very excited to get it flying!!!
The width of the motor are now 450mm and original are 350mm.Any different from the original?
Just want to remind you something,Yes you can, here's an FAQ I wrote Battery Modification for DJI Phantom 3 FAQ
Before you put anything on the body shell;
1. Get a 1mm drew bits to drew down the holes beside of the arms metal bits, also the top end body shell both side have tew holes on each side (same looking type of holes ).
Before you put that metal bits in, you must enlarge the bottom hold otherwise it is very hard to go down.
2. When you putting the cable protective tube on to the arms, the back right arm protective tube must be atleast 4cm long extended out form the arms. If not when you fold it back up that cable will go in to the battery compartment area which is annoying when you put a battery on.
3. The antenna on the arms must 90 degree facing out side.
Thats all about it.
Installing that for P3S will be more difficult, P3P/A are easier.enjoy.
thanks for the tips. I found that, once i had the right screws in the right places, all went perfectly fine. I think thats the key and is why i made a screw install guideI'd be hesitant to drill out the plastic to be honest, but to each their own
Great point about the protective tube .. and also remember to loop the back antenna wire so it doesnt get caught in the battery area.
About the anteanna, all the how-tos say to put at a 45 degree angle. You are suggesting 90 degree .. have you tested both? Curious which gives better. I know silverwingflix did a antenna mod as the 45 degree didnt work too well.
great info!! im getting the soldering iron out right now to address solders on the remaining two arms, will keep everyone posted. Thanks again for the great discussions here, didn't expect this thread to get so many hits!
Alright so at this point i have it entirely put together, but having an esc error when i fire motors. I need to take it apart and redo some soldering to the mainboard. I leave town this weekend for a week, so you guys may not see me fly this for 1-2 weeks. Here's pics in the mean time
After you mention, I go to the original page to double check, yes he did it other way round.Hi,
I gonna build mine and something is odd about the motors... instruction says: black motor on top left and bottom right but you made it opposite?!
Get a knife to scratch out the material and solder itJust finished mine, getting esc error. I made a mistake and cut the motor wires originally.
Do not cut your motor wires, do that!!!!!!
Some Newer (800kv) motors have enamel coating on the wires which makes it almost impossible to solder back.
Will take it all apart and try again, hope I don't need to buy new motors
Well who ever is willing to do the work for $$& let me know. I would like to convert but after seeing the vid ouch.
