- Joined
- Jun 2, 2016
- Messages
- 226
- Reaction score
- 160
10 bux never used
Having fun ?
10 bux never used
Having fun ?
Problem ?Having fun ?
Problem ?
Here is the script log, I save it at /etc/init.d when test, so pls ignore the path
/etc/init.d # ./setchan.sh
Checking Connection with Phantom 3 Standard / 4K . . .
Connection - OK.
Channel 1 - In Use
Channel 2 - In Use
Channel 3 - In Use
Channel 4 - In Use
Channel 5 - In Use
Channel 6 - In Use
Channel 7 - In Use
Channel 8 - In Use
Channel 9 - In Use
Channel 10 - In Use
Channel 11 - In Use
Channel 12 - Not In Use
Set CH to 12
Try To Setting Channel = 12 . . .
Patched channel=12
Connected . . .
Patching Phantom 3 Standard / 4K at 192.168.1.2 . . .
Entering character mode
Escape character is '^]'.
BusyBox v1.22.1 (2015-06-29 19:28:31 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
/ # iw reg get
country US: DFS-FCC
(2402 - 2472 @ 40), (N/A, 30), (N/A)
(5170 - 5250 @ 80), (N/A, 17), (N/A)
(5250 - 5330 @ 80), (N/A, 23), (0 ms), DFS
(5735 - 5835 @ 80), (N/A, 30), (N/A)
(57240 - 63720 @ 2160), (N/A, 40), (N/A)
/ # iw reg set BO
/ # iw reg get
country BO: DFS-JP
(2402 - 2482 @ 40), (N/A, 30), (N/A)
/ # iw dev wlan0 set txpower limit 2700
Patching Phantom 3 Standard / 4K - RC . . .
Restarting AP, it may take a moment . . .
Configuration file: /var/run/hostapd-phy0.conf
Using interface wlan0 with hwaddr 60:60:1f:0b:d8:db and ssid "GaryKan-P3"
wlan0: interface state UNINITIALIZED->ENABLED
wlan0: AP-ENABLED
Checking Final Result at 192.168.1.2 . . .
/ # iwinfo
wlan0 ESSID: "GaryKan-P3"
Access Point: 60:60:1F:0B8
B
Mode: Client Channel: 12 (2.467 GHz)
Tx-Power: 27 dBm Link Quality: 70/70
Signal: -37 dBm Noise: -95 dBm
Bit Rate: 130.0 MBit/s
Encryption: WPA2 PSK (CCMP)
Type: nl80211 HW Mode(s): 802.11abgn
Hardware: unknown [Generic MAC80211]
TX power offset: unknown
Frequency offset: unknown
Supports VAPs: yes PHY name: phy0
Checking Final Result at RC . . .
B
Mode: Master Channel: 12 (2.467 GHz)
Tx-Power: 27 dBm Link Quality: 65/70
Signal: -45 dBm Noise: -95 dBm
Bit Rate: 65.0 MBit/s
wlan0.sta1 ESSID: unknown
Access Point: 00:00:00:00:00:00
Mode: Master (VLAN) Channel: 12 (2.467 GHz)
Signal: -39 dBm Noise: -95 dBm
Bit Rate: 78.0 MBit/s
Encryption: none
Patch Completed, Enjoy.
/etc/init.d #
Log for execute with INCORRECT User argument input
/etc/init.d # ./setchan.sh 555
Connection - OK.
User argument = 555
Input Error : Channel must be 1 to 13 !!
/etc/init.d #
Log for execute with User argument input
/etc/init.d # ./setchan.sh 13
Connection - OK.
User argument = 13
Try To Setting Channel = 13 . . .
Patched channel=13
Connected . . .
/ # iw reg get
country US: DFS-FCC
/ # iw reg set BO
/ # iw reg get
country BO: DFS-JP
wlan0: AP-ENABLED
/ # iwinfo
B
Mode: Client Channel: 13 (2.472 GHz)
Signal: -33 dBm Noise: -95 dBm
Bit Rate: 57.8 MBit/s
B
Mode: Master Channel: 13 (2.472 GHz)
Signal: -40 dBm Noise: -95 dBm
Bit Rate: 60.6 MBit/s
wlan0.sta2 ESSID: unknown
Mode: Master (VLAN) Channel: 13 (2.472 GHz)
Signal: -31 dBm Noise: -95 dBm
Encryption: none
/etc/init.d #
I was trying to help him out. With my crap. You must have alot of important problems in your life worrying about one post LOL. Good job. Now I have to get back to real problems.
Is the benefit of channel 13 just due to less interference? That script seems like a lot of bother just to change the channel. Although if you were in a congested area with channel 13 free then I suppose it makes sense.
Confirm. I also changed to FCC (check: 27 dBm via telnet, drone and remote) but after received GPS signal and recorded home point (Poland) it again back to 17dBm (CE)Thank for your efforts. I tried to change the mode to FCC. I did check the message that was changed US without GPS signal(indoor) But, it was returned back to GB(CE mode) when my drone received GPS signal and recorded home point.
Here is my script for Auto scan best channel from 1 to 13 (set unused channel), it will patch RC and drone as same time, then show wifi detail result after patch completed.
I don't touch DJI original /sbin/chansel because it is a binary file and I don't know what it done
so let's the original boot process complete, then execute custom script to avoid bricke the RC
- How to install
1) save script as "selchan.sh" at /sbin and chmod 775
2) enable telnet.d in rcS file at rc and drone
3) Patch force FCC mode if necessary
4) turn on rc and drone
5) telnet 192.168.1.1 and execute selchan.sh
6) check onscreen result, if result ok with no error, add "sleep 30" and "selchan.sh" in RC rcS file at last line to make it auto run when boot (sleep 30 for avoid script run b4 drone connected to RC)
7) user also can execute with argument to set channel number manually, eg : selchan.sh 13
PS: if you want to disbled telnet.d after make it auto execute when RC boot, You can add "iw reg set BO" in rcS at both side and remove "#patch drone side to BO" inside the script
PS2: Wifi channel can be change during in flight ! execute the script by android telnet program, and video downlink stream in DJI GO will be resume after network restart completed !!
#!/bin/sh
#Auto scan and set unused Wifi channel for Phantom 3 Standard / 4K
#Author : Gary Kan
#Date : 14/06/2016
#Version 1.0
clear
DRONE="192.168.1.2"
###Make Sure network is ready and Drone side is online
echo "Checking Connection with Phantom 3 Standard / 4K . . ."
ping -c 1 -w 30 $DRONE &> /dev/null
if [ $? -ne 0 ]
then
echo "ERROR : Phantom 3 Standard / 4K at $DRONE is unreachable"
exit 1
else
echo "Connection - OK."
fi
###Check unused channel or user argument
if [ -z "$1" ]
then
for i in 1 2 3 4 5 6 7 8 9 10 11 12 13
do
iw dev wlan0 scan | grep "DS Parameter set:" | awk '{FS=" "} {print $5}' | sort -n | grep -x $i &>/dev/null
if [ $? -ne 0 ]
then
echo "Channel $i - Not In Use"
echo "Set CH to $i"
CH=$i
break
else
echo "Channel $i - In Use"
if [ $i = 13 ]
then
CH=$i
fi
fi
done
else
echo "User argument = $1"
case $1 in
1|2|3|4|5|6|7|8|9|10|11|12|13)
CH=$1
echo "Input Error : Channel must be 1 to 13 !!"
exit 1
esac
fi
###Setup hostapd-phy0.conf with target channel number
echo "Trying To Set Channel = $CH . . ."
sed -i "/channel=/c\channel=$CH" /tmp/run/hostapd-phy0.conf
echo "Patched `grep "channel" /tmp/run/hostapd-phy0.conf`"
echo " "
###patch drone side to BO, make sure ready for CH12,13, telnet.d must be on in rcS, can be remove if user set country = BO in rcS at drone side
if [ $? -ne 0 ]
then
exit 1
else
echo "Connected . . ."
echo "Patching Phantom 3 Standard / 4K at $DRONE . . ."
{ sleep 1;echo "iw reg get";echo "iw reg set BO";echo "iw reg get";echo "iw dev wlan0 set txpower limit 2700";sleep 1;} | telnet $DRONE
fi
###Patch RC Side and restart network
echo ""
echo "Patching Phantom 3 Standard / 4K - RC . . ."
iw reg set BO
sleep 1
echo ""
echo "Restarting AP, it may take a moment . . ."
kill -9 `cat /tmp/run/wifi-phy0.pid`
sleep 1
/usr/sbin/hostapd -P /var/run/wifi-phy0.pid -B /var/run/hostapd-phy0.conf
sleep 1
###Final Checking, can be remove
echo ""
echo "Checking Final Result at $DRONE . . ."
if [ $? -ne 0 ]
then
exit 1
else
{ sleep 1;echo "iwinfo";sleep 1;} | telnet $DRONE
echo ""
echo "Checking Final Result at RC . . ."
iwinfo
echo "Patch Completed, Enjoy."
fi
if you save the script at /sbinSingLag
Can you tell me why the script inst running for me?
no need to use ./, just type setchan.sh (your file name selchan.sh)
Yeah that didnt work either. I had to force it with sh. But now I am getting this.
/sbin # sh selchan.sh
: not found line 6:
: not found line 7: clear
: not found line 8:
: not found line 10:
selchan.sh: line 27: syntax error: unexpected word (expecting "do")
/sbin #
Managed to attempt this but controller now won't connect to drone - ****. Any ideas?
I edited the rcs file as per the instructions and uploaded the file to remote and drone.
