No wifi from drone
Hello. I habegär just bought a White phantom 4 Pro. What a beast, sound like a big helikopter :-) .
Any way. It can fly. But there is something wrong with the gimball. So I was going to start byta connect my Phone to the controller to see if there was any "codes".
But I cant connect. My phon can not eventuellt se that Phantom sends out a wifi signal. I have tried the 2 different port on the controller. Notting happends.
I also have dji googles (White). Connecting with micro usb. The googles only want to find a mavic pro.
So. What should I do now? Any Ideas? I raly want this one to work. A realy awsome drone to fly :-) .
Need more info. Do you have a DJI account yet? is DJI GO 4 app on your phone that's linked by usb cable to the remote? Most importantly, is the remote linked to the drone (green light on remote, not red)? If so, the remote will operate the drone even without the phone attached but with no video feed. Phantoms are very simple machines to operate once set up properly and there's many youtube videos to help you get started.
be specific please what is wrong with the gimbal
Good point :-) .
When the drone is off is the camera npt straight. It points a little to the left.
And when I start it up the camera can only look down.
From the looks of the legs, it probably had a hard landing in the past. That could easily cause gimble problems like from a broken ribbon cable, a bent shaft or arm, weak gimble motor, etc. History of this drone is needed, especially before pouring money into elusive repairs.
Even when the drone has had a hard crash it would be helpful to get some more info for instance on color and action (flashing) of the front and back lights of the drone when the AC is on (see the P4P manual page 14 for explanations and the various patterns).
And how do you know it can fly without having your phone connected to the controller and or the drone to the controller ?
The drone will not connect via wifi to the phone but via the usb cable as mentioned above, I think you will need to read at least some parts of the manual ;-)
Sometimes the Phantom’s WiFi doesn’t show up right away - maybe try restarting both the drone and the controller, then check your phone’s WiFi list again. Also, make sure your phone’s location/GPS is turned on, because some DJI apps need that to detect the signal. For the goggles, they might only work with Mavic models, so that could be why they don’t find the Phantom.
