Phantom 3 Standard range mod , let's do it together...
Hello my friend.
Thank-you for this app very good job; but does it work with phantom 3 4k?
Tk.
Hello my friend.
The RC models is not the same, phantom 3, 4k RC looks like phantom 3 professional RC, but doesn't work with lightbridge like the pro, work with the same WiFi protocol like the P3S.
Please refer the script below, it's updated at some degree from the start.
It originally watched syslog changes, but it had sometimes missed CRDA update,
so I changed it to use information from iw, with use of grep. Script also simplified too.
I'm now thinking iw in the script loop cannot harm wifi connection, but in fact, we don't sure it under all circumstances.
I tried to make it robust & safe, but don't forget, use with care & experiment.
And it may contain CR in the script, so in that case, clear ^M with sed and check with vi in the telnet.
*** Don't use the script unless you know what are you doing ***
I will learn your script and add later.
thank you.
Hi,
I modified PapaTipa's script a bit for my own use and changed the region to US. Tested it yesterday and managed to usable range of 1,4km with P3-4K + windsurfer, video worked quite smoothly the whole time and there wasn't any significant delays. Started getting issues with the control signal after 1,4km.
Hello.
Did you try it in phantom 3 4k (the new with the RC that looks like phantom 3 pro) with out problems??:)
Thank you
Hello.
Thank you
Yup, Phantom 3-4k with latest firmware. Modified the script a bit but it's basically the same.
Ok very good, but can I try it with out modification? I don't know how to modified anything:eek:, that's why I want to used this app. but I don't want to brick the bird.
Thank-you my friend
Thank-you my friend
I don't see any reason why you couldn't use the original one. I just changed it to US region and didn't include the automated start function. Ofc i can't take any responsibility if anything goes wrong but it worked just fine for me.
New Feature.
Sent from my Redmi Note 2 using PhantomPilots mobile app
Hi
Nice work...
The option "revert to 17 dbm" will revert the changes exactly to stock??
On the script there is a country option UK that is changed to US.... There are only UK or if in france would appear FR in spain SP, etc???
Hi
Nice work...
This application add only one file into the system which will then be executed periodically, by simply closing this file as well as back into stock
Can anyone advise? After the whole proccess i am still in CE :/
Disconnected.
Disconnecting.
07:12 ============================================
07:12 Restart your RC & Aircraft and Enjoy New Mod
07:12
07:12 Credit to: Ojcze Nasz, SingLag, Argonaise & www.phantompilots.com
07:12 File upload OKE
07:12 Checking file ...
07:12 Configure Telnet
07:12 Reconfigure djiled.sh
07:11 Final process ...
07:11 hmod 775 /sbin/watchlog.sh
07:10 c
07:10 chmod 775 /sbin/watchlog.sh
07:09 winfo
wlan0 ESSID: "PHANTOM3_054f88"
Access Point: 60:60:1F:05:4F:88
Mode: Master Channel: 10 (2.457 GHz)
Tx-Power: 17 dBm Link Quality: 70/70
Signal: -21 dBm Noise: -95 dBm
Bit Rate: 86.6 MBit/s
Encryption: WPA2 PSK (CCMP)
Type: nl80211 HW Mode(s): 802.11abgn
Hardware: unknown [Generic MAC80211]
TX power offset: unknown
Frequency offset: unknown
Supports VAPs: yes PHY name: phy0
wlan0.sta1 ESSID: unknown
Access Point: 00:00:00:00:00:00
Mode: Master (VLAN) Channel: 10 (2.457 GHz)
Signal: -6 dBm Noise: -95 dBm
Bit Rate: 130.0 MBit/s
Encryption: none
07:08 i
07:08 iwinfo
07:07
BusyBox v1.22.1 (2015-11-16 16:28:58 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
07:07 Aircraft Ready ...
07:07 RC Ready ...
07:07 Telnet ready ...
Connected.
Connecting to 192.168.1.1.
07:00 File upload OKE
07:00 Checking file ...
07:00 Upload watchlog.sh
07:59 File upload OKE
07:59 Checking file ...
07:59 Upload djilet.sh & Configure Telnet
07:58 RC Ready ...
Ok, i have restarted the dron and RC and hit STEP 2 and this showed up, am I in FCC now?
Disconnected.
Disconnecting.
07:53 ============================================
07:53 Restart your RC & Aircraft and Enjoy New Mod
07:53
07:53 Credit to: Ojcze Nasz, SingLag, Argonaise & www.phantompilots.com
07:53 File upload OKE
07:53 Checking file ...
07:53 Configure Telnet
07:53 Reconfigure djiled.sh
07:52 Final process ...
07:52 hmod 775 /sbin/watchlog.sh
07:51 c
07:51 chmod 775 /sbin/watchlog.sh
07:50 winfo
Mode: Master Channel: 6 (2.437 GHz)
Tx-Power: 27 dBm Link Quality: 70/70
Signal: -27 dBm Noise: -95 dBm
Bit Rate: 122.8 MBit/s
wlan0.sta2 ESSID: unknown
Mode: Master (VLAN) Channel: 6 (2.437 GHz)
Signal: -10 dBm Noise: -95 dBm
Bit Rate: 115.6 MBit/s
Encryption: none
07:49 i
07:49 iwinfo
07:48
07:48 Aircraft Ready ...
07:48 RC Ready ...
07:48 Telnet ready ...
Connected.
papatita bisa bantu betulin p3 4k yang brik ngak.
saya edit rcS di drome dan RC sekarang ngak bisa ditect wifi ap.
tapi dari rc ke drome bisa connect dan terbang.
thanks
Moved them today, bit of a bodge, ill tidy it up. Used 3m moulding tape. used for car trim, no parts needed.
Reactions: hexagon
Have you noticed any improvements? Are they 2.4 ghz video antennas?
Yep, I found flying sideways i could fly further, so i popped the top off, took the 4 screws holding the mobo out, and levered the antennas out(without removing the mobo). Dont see the point in running cables in only to come back out, so they are wired externally directly to the cam now.
jiwaya
