Phantom 3 SE doesn't fly, any suggestion
Hi phantompilots, im in french polynesia, i've a PH3 SE new, my phone is a xiamoi 6.4" MAX2, i've installed the modded 1.3.18 v of DJI GO because the version of the playstore gave me "wifi" problems, now that all seems ok i try to fly but the drone doestn't do it, i attach you some caps and video, help me please
I see you are indoors. It wont start up while in beginner mode with no GPS lock. Is that it, or are you having the same issue outside?
Reactions: Neon Euc
with or without the app the drone starts up well, camera do the check up/turns and helices do a check up moving a little also but it doesnt fly
what i dont understand is why when i try to change the wifi config in the app to 2.4ghz it doesnt let do it
I was reading these before I posted to try get idea but not find much,,I'm still having a search on this
...for some reason a stick calibration jumped in my head,
Reactions: MotorCycle-Man
well, i've put off beginner mode, it doesnt fly. I've checked wifi 2.4 channels, they are 11 which means im in FCC, is this config the good for French Polynesia?
is it important the data "countrie" when i open the account on dji, if yes which may i indicate then? French Polynesia or FRance?
Um unsure on modified version I stick to what playstore gives,I sort of thought it choose fcc or ce automatically ,this other post I find says can't be changed unless your phone is 5G capable so getting unsure on that sorry,but I keep searching
I wouldn't rely to much on the phone list to be honest. I also have an imported Chinese phone and all 3 of them have no issues and yet they are not on the list. Your phone is fine phantom3SE PF, I would recommend trying to link the controller to the drone first. The WiFi is a tricky one to do and I remember it gave me a hassle trying to figure it out. I think what I done was make sure the home WiFi was turned off as it was causing problems and confusing the drone
Neon Euc, i think as you, the problem is not on the phone. Well, according to the fact of linking the controller to the drone: IN P3 SE is not possible, you find the option on the DJI GO, you can click it, it give it 60 seconds to introduce something and push a bouton on a small hold but THERE IS NO BOUTON, when i introduce the thing i dont find any bouton, it doesn't exist. It's not possible to link the controller in P3 SE. I'll try to send you pictures now.
I've done all this:
Switch ON the wifi on the SM
Switch ON the GPS on the SM
Switch ON the RC
Switch ON the drone
Verify that drone is well connected on Wifi Settings of SP
Open the DJI GO, select PHANTOM 3 SE and go to CAMERA
After several Seconds it indicates "READY TO GO"
I've gone to RC Settings and i've clicked to RC LINKING option
The green bouton on the drone has became red
I have pushed it and it has changed to green
A small windows on the SP has confirmed RC LINKING finished
I've tried to fly the drone moving all the controls but NOTHING the drone doesnt fly
So the problem is not the RC LINKING.
The little light that’s flashing IS the button! Push it in gently!!!
I've done all this:
Switch ON the RC
Switch ON the drone
Did you try the 'Auto Take-off' button on the left side of the screen in the DJI GO app?
hcashmore11
