Phantom 3 professional , crtitcal low voltage error message....
Hello everyone, today something strange happens. I wanted to take some photos, I have with me two batteriesat 100 %, start to fly and after a few minutes I see that brand in red tensions and begin a controlled descent.
Once on the ground I turn and control.
Battery brand about 50% log file, always on the 50/60%
Redo some test flights also changing the battery. Before flight flight while 50% the percentage changes little, but all cell voltages from 3.8V to pass 3.3-3.4 turn red and start the descent.
Strange thing the percentage never changes.
Android app, set to 10% and 30% Critical Warning Low Battery.
Rissettarli tried but it does not change anything.
I do not have with me today a device IOS to do other tests.
If you check the battery with led me by about 50% and 100% load life.
I reinstalled Android app, no change.
If you check the flight recorder does not give me anything strange, indeed had to be able to fly to other minimum 10min .....
Ideas?
Thank you
Assuming I translated the question correctly, it sounds like your battery is not fully pushed into the battery bay.
