Phantom 3 pro - camera is fine but gimbal is not working
Hello, I've recently managed to crash my Phantom 3 pro. I changed the yaw arm and also the flex cable, now the camera is working just fine, also the phantom itself is working (GPS, Take-off, etc.) but I can't move with the camera - the stabilisation is not working at all. Is there any way to repair it by myself or do I need to order the whole camera + gimbal part from DJI?
Thanks!
Did u use a DJI cable? Some of the after market cables will do that. There are places that can fix it for u. What country are u located in? I repair them here in Florida and a guy named Hunch does them in Minnesota. The cost would be reasonable. Probably a ribbon cable. I could turn it around and back to u in a couple of days if the main board is good. If u have video it probably is.
If u used a DJI cable check the connections again.
The problem is that I'm from Slovakia and the nearest DJI repair service is in Germany. Can I somehow check if the main board is damaged?
canadiansauna
