phantom 3 led
I crash my ph 3 standard and have taken it apart and Some of the led wires are broke right at circuit and cant be soldered. Has any ph3 stand owners
had leds fail. I am thinking of running wires over to the leds that work as a source of power. tx
On the bottom side of the main esc board, where the LED solder positions were, look carefully and you will see small round dots. Careful clean the black protective coating off of the ones that you need to solder. Pay attention so as to solder the correct wire to the proper contact point. It’s kind of a pain in the butt to do because you need to remove the ESC board from the drone to get proper access.
