Phantom 1.1.1 motor problem
Started having a problem with motors m2 and m4. When powered up they chatter and do not turn fully. Tested and confirmed problem in Naza Assistant. They worked fine until I installed a gimbal and connected a wire from the gimbal board to the Naza controller (F2) for pitch control. I have since uninstalled the wire but the motor problem persists. Does anybody have a fix for this.
Thank you.
Did you remove your prop guards at the same time?
Jerry P
