P4 Problems Calibrating with Assistant 2 (Reboot Aircraft)
Florida
Greetings!
I am having an issue with a Windows 10 PC, using the latest version of DJI Assistant 2. It connects to the PC without an issue, just when I try to calibrate the VPS it says Reboot Aircraft and the Calibrate now button is grayed out.
I have tried uninstalling/re-installing Assistant, manually updating the x64 drivers and still no luck, tried disabling the device signature verify as well.
Anyone have any suggestions?
While in the Assistant 2 App, complete a Factory Refresh under the firmware tab. Then try to calibrate the VPS. If you need to sync any of your flight records do so before doing the refresh.
Thanks for the suggestion. Still no luck. It says downloading V02.00.0700, then transmitting. It finishes, reboots the craft, and still will not allow into the Calibration portion of Assistant 2.
akinproplumbing
