KachemakDiver
Premium Pilot
The 1.4.10 is probably the last firmware version that was successful updated to the drone when you attempted the 1.11.20 update.Ah no, I should have specified that I was using a fan from the very first attempt, that was something that was repeated frequently when I first got my AC and joined.
I can give that a shot, but I'm still curious as to why that particular version of the FW is even there or shown, I have never tried to install FW v1.4.10.
The DEBUG file needs to be on the sd card first before the firmware update file.
Yep, that's clearly covered in the linked thread but on my AC the Service File did not function. Which may be because the FW update failed midway.The DEBUG file needs to be on the sd card first before the firmware update file.
Nope, that can't be it. As stated in my first post my AC had never been updated past v1.2.6 until the v1.11.20 attempt.The 1.4.10 is probably the last firmware version that was successful updated to the drone when you attempted the 1.11.20 update.
You may be right. I'm taking a break for dinner, may try a v1.4.10 update after that. Although my wife may prefer some time spent with her too. LOLVery glad to hear that about the "fan all along"
I speculate that something that something made its way from one of the partially complete (but failed) FW updates made its way onto the AC. The "About" function check recognizes it as v1.4.10 ..... but with things missing, so it adds the +.
So, if you can just get one "complete" set of FW to install ... upgrading or downgrading from there should be easy peasy![]()
Yes, it makes you want to keep a logbook of all the procedures that you have tried, along with the outcome.Thank you ....... that is an important point I did not point out. It is little details like that that drive you crazy when trying to sort out a problem !!
That’s what I was saying,,, when you were updating to version 1.11.20, the firmware stopped updating at version 1.4.20.
Ah, sorry, my mistake! Thanks!That’s what I was saying,,, when you were updating to version 1.11.20, the firmware stopped updating at version 1.4.20.
No worries,,, I hope you get it all solved.Ah, sorry, my mistake! Thanks!
I believe that your gimbal board needs to be re-flashed.3 attempts to install v1.4.10 and all failed, tried with two freshly formatted SD cards just in case. But this time a LOG_AB file was created! It is attached in case it helps figure this one out.
I take it this is something that cannot be done at home since a quick Google search yields no how-to results.I believe that your gimbal board needs to be re-flashed.
@quaddamage has a thread on here that tells how to do it. It is quite a long thread so be sure to read it all. In the thread it mentions a member by the name of @Suncatcher, he has a link that is shows how to do it perfectly.I take it this is something that cannot be done at home since a quick Google search yields no how-to results.
Thanks! Sort of what I expected to read, but I'm not sure if I'll have the time to thoroughly learn and attempt a procedure of that magnitude anytime soon unfortunately.@quaddamage has a thread on here that tells how to do it. It is quite a long thread so be sure to read it all. In the thread it mentions a member by the name of @SunsetCatcher, he has a link that is shows how to do it perfectly.
It’s really not hard to do. But you do need some soldering skill, and the usb tool.Thanks! Sort of what I expected to read, but I'm not sure if I'll have the time to thoroughly learn and attempt a procedure of that magnitude anytime soon unfortunately.
Yes, you sure can.My soldering skills are a bit rudimentary. lol
Out of curiosity, since this problem is on the gimbal board, could I just replace the gimbal assembly or the gimbal board itself with a known working one?
So to make sure I'm not getting ahead of myself, say I get a gimbal board that is loaded at v1.3.20, is there anything else on my AC that's affected by my original attempt to update to v1.11.20 (or getting stuck at 1.4.10)? Basically just checking to see if there would be any incompatibilities between AC and replacement gimbal board by going this route.Yes, you sure can.
The app shows that the firmware version is 1.4.10+. So being that you would be using a different gimbal board, as soon as you power it up, the app will show you if the camera and/or battery needs updating. If you buy a gimbal board that has been re-flashed, then that board will have been reverted back to old firmware.So to make sure I'm not getting ahead of myself, say I get a gimbal board that is loaded at v1.3.20, is there anything else on my AC that's affected by my original attempt to update to v1.11.20 (or getting stuck at 1.4.10)? Basically just checking to see if there would be any incompatibilities between AC and replacement gimbal board by going this route.
Ok, I think I'm following. I'm going to get a little specific here because this might clear it up for me.The app shows that the firmware version is 1.4.10+. So being that you would be using a different gimbal board, as soon as you power it up, the app will show you if the camera and/or battery needs updating. If you buy a gimbal board that has been re-flashed, then that board will have been reverted back to old firmware.
