New member, 2nd P3 Adv project
Evening all,
Picked myself up 2x PA3 Adv over the weekend...
The one I'm working on rebuilding has a number of issues, namely
Cameras gimble unable to get a lock
AC flashing red when turning on
Double beep when turning AC on
Disconnected connector above ICU
Finally managed to get the controller to connect to my phone, shows Main Controller error.
Fw shows as requiring update
Battery shows as requiring update
Gimble alignment doesn't go beyond 2%
Have looked at test downs of the ICU, and that connector doesn't look too be from there.
Gimble "flat edge of axle" is aligned correctly etc
Long story short, thanks for letting me join, I'll no doubt be posting and have a few queries as I progress, so any advice gratefully appreciated! 🙂👍🏻
Welcome to the forum! Many members here will be more than happy to help with any issues you have during your restoration project.
Reactions: RodPad
Evening all,
Above all, DON'T update the drone's firmware! It usually causes more trouble than it's worth.
Evening all,
not bad quads but outdated now
Lock? what do you mean
Usual cause is lack of satellites, you need to get enough to lock a home point until then its red to warn you not to fly
Could be a bad ESC
Main controller is the brains without someway to determine the issue it will be hard to trouble shoot
As Dan says never ever ever update
This is done along with the FW update see above point
Gimbals are delicate things, also very complicated, usually best just to buy a replaceement
No idea about this
Always a good thing to check
We will try our best
Greetings from Birmingham, Alabama
Reactions: Daniel NZDF
