I provided some history to my mishap, but my questions are in bold if my intro got too long winded.
I had my P2V+ Flip over on while taking off from a rock near a stream. The rock was somewhat tilted but it was the only spot I could get enough satellites. A mistake I won't make again. Anyway, it flipped before fully in the air and landed upside down in a couple inches of water. I grabbed it out in about 5 seconds. The gimbal and camera did not get wet but enough water got into the hull.
I removed the battery, shook the water out of it, rigged a fan to blow air through the battery opening for several hours, sealed it in a bag of rice overnight and today I took the top shell off and sprayed the boards with 91% isolpropyl alcohol. I let this sit in the sun and will again put it in a bag with rice tonight, The 2 areas I can't see are the inside of the wifi module, which I removed and have in its own rice bag & the flight controller.
Its obvious the vented wifi module could have water in it. I sprayed it with alcohol and will rice bag it again. I have a couple questions:
The flight controller looks like it could be sealed. Does anyone know if it is?
If the flight controller doesn't likely have water in it, I think I will soon be at the point of trying some tests. I'd like to try the initial ground tests without the wifi in place and the camera disconnected.
Should the P2V+ power up its motors with the wifi module out?
If the initial tests look OK, should the P2V+ fly (just a low altitude test flight) without the Wifi module?
Thank you,
Thank you,
