Selling Phantom 4 pro plus controller only how to prep it, drone damaged
It does mean the next one is cheaper since you have remote
or
you could open the shell up to let it dry out good,battery toast but might still work if the water was fresh,,salt water bad,,
Reactions: captainmilehigh
The correct way to salvage a drone is to wash all parts individually with distilled water. After drying, water leaves no traces.
Before turning it on, you should inspect all the boards to see if there are any signs of through corrosion. Usually only the battery dies.
Reactions: IANZONE
