Hey guys if your looking to mod your bird with dipoles check these out. These are a great match if your using DBS Itelite panels. These are a lot better than the other ones out there and are strong and use silver plated coax. 2.4GHz Bazooka Dipoles
Those look a lot better that the FPVLR ones I have . If he would come out with 5.8's I might have to just give em a try .
I use both on my Standard .
Well lets ask @JakeMaxxUAV is they are going to make them![]()
Just curious as to what exactly these are. I have already modded my controller and have both the Itelite DBS02 and Maxxrange antennas. Are these dipoles an alternative to the panels? I was actually also thinking of buying and testing out the FPVLR antennas. Correct me if I'm wrong, but isn't the FPVLR that replacement antenna that has the two curly q coil looking things on it? lol. Just learning here guys, by the way, I love my Maxxrange. Flew out two miles today unboosted. 12,110 ft. And still made it back with 36% battery.Hey guys if your looking to mod your bird with dipoles check these out. These are a great match if your using DBS Itelite panels. These are a lot better than the other ones out there and are strong and use silver plated coax. 2.4GHz Bazooka Dipoles
These are to modify the birdside (aircraft antennas) antennas for added range, better turnarouds or to explore, perfect match for Maxxrange or Terminator antennas on the rcJust curious as to what exactly these are. I have already modded my controller and have both the Itelite DBS02 and Maxxrange antennas. Are these dipoles an alternative to the panels? I was actually also thinking of buying and testing out the FPVLR antennas. Correct me if I'm wrong, but isn't the FPVLR that replacement antenna that has the two curly q coil looking things on it? lol. Just learning here guys, by the way, I love my Maxxrange. Flew out two miles today unboosted. 12,110 ft. And still made it back with 36% battery.
One more question, thanks for the explanation. I thought I had read somewhere that the fpvlr(circular) will give more penetration through trees. Is this true?These are to modify the birdside (aircraft antennas) antennas for added range, better turnarouds or to explore, perfect match for Maxxrange or Terminator antennas on the rc
The Maxxrange panel polarity matches the the stock birdside antennas or the bazooka dipoles, fpvlr circular polarized antennas do not. I mean they will still get you farther than stock but not farther than the Maxxrange. Check out some of the P3 leader boards, the top spots are using Maxxrange or Terminator.
You are correct, the fpvlr are the coil ones! (Circular polarized)
Maxxrange and Terminator are linear polarized patch antennas
Sent from my SM-G900V using PhantomPilots mobile app
Sure, just tie a piece of rope to it and throw it at the valve lolCan I also use one to shut off the water at my house?
