Original firmware Phantom 3 SE
Hi Chatikib i downgraded my Se with the firmware you posted, it fly well and i did a LITTLE improvement in range (550mt), you said that your Se works with Litchi IOS version....but you tried also waypoint mode? All the Litchi features work? Because i purchased the Android version and absolutely nothing works....
Best regards
Andrea
Best regards
Andrea
Litchi doesn't work on a Android. You need iOS (Apple).
Question about running the bird with old firmware! Is it possible? If i can recall correctly, i could not take off unless i upgrade, when its showing and flashing in red at the top on the main screen that firmware is required....
Thanks!
Thanks!
You do not need the new firmware; without it you can use your bird as normal. There is no risk to ignore it.
How do you ignore the upgrade? when i try to start the propellers the app does not let me. Its telling me that the plane is locked and the flashing back lights are solid red color.....
See this:
jorge sanchez
