Optimal Facebook live stream conditions?
Anyone familiar with Facebook live streaming and the optimal conditions / settings? The last couple of times I've tried it so laggy and sketchy its unwatchable. Any suggestions would be appreciated. Thanks
Facebook recommends 720 or 1080P at 30 FPS or less.
A fast LTE connection from your device is also recommended.
I have had good results with those settings although FB live streaming is not the best as they compress it quite a bit.
Reactions: beamerbuilder1
Ok that was probably the problem. I was shooting in 4K. I'll have to take the resolution down to 1080p and see if the resolves the issue. Thanks for the info Blue Bird.
Reactions: Drone Master
