No, they will automatically shut down after a short time with no props.Some motors require a load to work correctly and i dont want to try if it will harm them.
Thank you. Good to knowNo, they will automatically shut down after a short time with no props.
Ok now I feel safe to try and listen to my spindlesAs has been said- the motors require no load to operate. Speed is tightly controlled by line frequency. They will not over rev and destroy themselves like a DC motor or unregulated petrol engine might. Simple analogy is the spindle motors on my SNC routers, they are three phase 2 pole so at 300hz line frequency they run at 18000 rpm whether they are loaded by the cutter or free of the job. The phantom motors are simply miniatures versions of the spindle motors.
Approach KV rating? There is absolutely no fear of the motors over revving. They are driven by a sine waveform, rotor speed is locked to line frequency. The no load speed will be identical to that as with props for any commanded throttle setting. The drive waveform looks nothing like you ordinarily see from a typical BLDC ESC. It is very clean, I was surprised when I hooked up my oscilloscope to the motor fly leads.It is recc'd not to hit max throttle for too long as the motors will approach their KV rating ... but general test running is no problem at all.
As another says they do have speed limiting but its based on the AC style of 3 wire power to them. The power is basically pulsed and will only hit a max figure and that's it.
Nigel
This is bot a consideration for a phantom 3. Propellor or no propellor fitted the motor speed is deermined exclusively by the throttle position. The point you seem to have missed is that the motors are driven by a sine wave, not simply chopped DC as with basic ESC. The speed is determined by line frequency and number of poles, as is the case with any synchronous AC motor.Over-revving is not what I said or intended.
No BL motor reaches its KV rating ... because of load ... but running without load allows the motor to approach KV rating rpm.
For those others confused ... KV is basically RPM per Volt. In theory a 1000KV motor could give 1000rpm for each Volt applied ... in practice it falls far short of that due to load.
Allowing the motor to rev up to that should be fine but budget motors have been known not to like it ...
Nigel
So what ur saying is that these are actually synchronous ac motors and are actually powered by on board ac invertors with variable frequency?This is bot a consideration for a phantom 3. Propellor or no propellor fitted the motor speed is deermined exclusively by the throttle position. The point you seem to have missed is that the motors are driven by a sine wave, not simply chopped DC as with basic ESC. The speed is determined by line frequency and number of poles, as is the case with any synchronous AC motor.
They are BLDC motors driven by variable frequency sine wave drive (inverters controlled by an SOC). The speed is, as with any AC synchronous motor determined by line frequency. The motor back- EMF and phases currents are constantly interpolated to determine rotor position and modify the drive signals to very accurately regulate the RPM. While the TI motor drivers mimic a tupicall RC ESC they are significantly more advanced in their operation.So what ur saying is that these are actually synchronous ac motors and are actually powered by on board ac invertors with variable frequency?
You aren’t comparing apples with apples here, the phantom 3 motors are not driven by a basic ESC, RPM is very accurately controlled independent of shaft loading.I can upload here many videos of Brushless motors running with different props and you can HEAR the difference in RPM let alone that I actually own and use a laser tacho which clearly shows change in RPM ...
But back to running the motors without props - as found - it is ok ... just not recc'd to go full throttle for long.
Nigel
I agree thats a very innovative and high tech design. Go DJI!They are BLDC motors driven by variable frequency sine wave drive (inverters controlled by an SOC). The speed is, as with any AC synchronous motor determined by line frequency. The motor back- EMF and phases currents are constantly interpolated to determine rotor position and modify the drive signals to very accurately regulate the RPM. While the TI motor drivers mimic a tupicall RC ESC they are significantly more advanced in their operation.
