No transmission signal pro 3
Hi, got a p3p no transmission signal,tried to download fw , 7 minutes into download just starts buzzing,red light on camera, every thing else work fine,still flys great, got telemetry,will record and take pictures,just no live feed to ipad , can anyone help
Did you let the buzzing go until it stopped by itself?
This is normal on some upgrades, you just have to let it go until it finishes. It may take 30 minutes or more. Just stick it in a room somewhere and close the door and walk away.
tried that,its not a beep that its doing just a long buzz
If your video link was working before you upgraded, and you have checked to make sure that the drone has upgraded by looking at the text file, then it must be the upgrade that's causing the problem.
You might try a technique used in forcing a downgrade. Look at the video in this link:
Try this method
P3X is for Pro.
Nip
