Thank you please let me know if you find anything outI will be working on it, I got the same problem,
4/18/16 Tested before Firmware
4/18/16 Installed Firmware, No Problems
4/19/16 Did IMU, ETC.
4/19/16 Test Flight Not good 1/2 way than 4/18/16.
4/20/16 Re-linked RC, Same-o
4/21/16 Many Tests, Home Made Windsurfer helped but can tell there a problem.
I been through this before..
Phantom 3-Std Weak Remote Signal
I will be back
Yes, mine also did this. I never gave it a thought. Probably some adjustment/calibration going on. Everything works fine.Didn't get very far last night, this was an option on my Android Friday the 15th.
Firmware now is 1.5.70, Now it is gone on the Android.
The IOS unit never showed a downgrade choice.
Did the firmware with the IOS, oops, should have used the Android, I don't know.
I made a lot of notes / pict's since I started the procedures.
Look at this clip, did yours do this?
Scary
I will be working on it again tonight, going to try a many downgrade attempts, and checking connections in the remote. I believe that the firmware can cause this problem and that it is a hardware failure that occurs and is never been fixable.
Are you fine on distance, mine is still crap, tried again last night.Yes, mine also did this. I never gave it a thought. Probably some adjustment/calibration going on. Everything works fine.
I am on the latest firmware. Flying in an area with some wifi interference I thought my range got worse after updating. RC and Video show full signal strengh but still disconnecting after 50-150 meters. So the strength is still good but it seems more affected by interference.Are you fine on distance, mine is still crap, tried again last night.
