- Joined
- Dec 19, 2015
- Messages
- 55
- Reaction score
- 22
- Age
- 55
Have you tested each motor using the test button on the naza assistant to see if the motors will work in general?
Spring loaded throttle would not have any bearing on this problem.
My feeling is that there is an issue with dual rates/travel adjust'. Plug it back into the assistant, flick all the switches, and see if you can get 100% travel.
But, rowing backwards, I notice you changed the Rx type in Naza from traditional to S bus (D bus, same thing). But the wiring from the RX to Naza is different in each case.
Traditional has T/A/Y/R- 4 servo wires. S/D bus has just 1 from the D bus output.
+1. And one of the old school I referred toI too have and do feel the problem is not obtaining 100% (1000) deflection.
While I cannot find anything I print, I too feel 1000 is needed to activate CSC (Motor Start & Emergency Stop).
There are several ways to TRY and work around this which come to mind:
1> Use sub-trim to adjust all channels to "0" at center stick, OR
2> Use end-adjust to adjust each channel to 1000 at full deflection, OR
3>May require both 1 & 2.
