NO! Crashed.. Can I repair it?
I was out flying.
Went up to 250 feet and then suddenly lost control.
After five minutes the dji vision 2 started vobbling and spinning directly down into the ground.
The gimbal came off.
Can I repair it?
Any repair DIY checklist
I was out flying.
Can I repair it?
Hi @bompaholm, I take it your gimbal is the standard one axis gimbal that comes standard with the V2? If you do a search in the above search bar you should find what your looking for. Hope this helps you;)
Also check out the V2 mod forum, very helpful
Depends on how bad it's damaged, might be repairable, weakest link is the 3 wire cable that feeds the servo, you can buy that as part of the vision cable pack. Spares for the gimbal itself are hard to find though, you may be best following the above advice and swap out the gimbal for a 2D version
Hello.
Please see Picture regarding the damage.
What do I need to order to fix it?
Thank you very much in advance.'
It seems like the reason why the drone crashed was screws that released from under the motor....
Scav8tor
