New Vision 2 plus unable to down load driver installer
Wiltshire
Our phantom hasn't even left the ground and we are having problems. I have downloaded vision plus assistant , Rc assistant but it will not download driver installer.
Have tried running it on windows 10 & 8, turned fire wall off, deleted cache, cookies and history, swore at it and even gave it 'the look' but no luck. Please someone offer advice on what I am doing wrong as at the moment all I can see is a lump of expensive plastic that is only good for the bin, also having to contend with a grumpy husband who wants to go out and play.
Forgot to mention when I attempt to down load it says download is corrupt. Have tried several different links but they all remain saying the same thing.
Windows 10 has to many problems. Of course windows 8 had it's own set of problems and that is why they came out with OS 8.1. My tablet use 8.1 OS and both assistant programs work on it.
As for the windows driver that has to be loaded into the P2 in order for it assistant software to be recognized. If you still cannot get it to work with either OS's find a computer with 8.1 or 7 OS.
I just followed link above and dl the driver
It is saying corrupt or etc but you can continue with install if you click thru the warning screens and messages about unsigned app etc.
once downloaded , highlight it and right click and chose run as administrator!
I dont have my p2 anymore to test but it did appear to install
off subject.
I have a 5 win 10 pc's at home and this is one .
No issues at all on mine , running over a year on 2 of them.
Fast and secure, 16 seconds from power button to typing.
Thanks for your help, have tried to save and run following your link but still coming up as 'the signature of dji_win_driver_installer.exe is corrupt and invalid'
you need to keep going past that screen ignore it
download zip file
go to file location it dl to.
click to extract all
right click on the extracted file
run as admin
it will pop red warning up---ignore it
click more info
click run anyway
good luck
I just did this now again to test
I read more about this problem. In my opinion it is a Windows 10 problem. I couldn't install the driver under Windows 10. Then I installed Windows 7 at that PC, and see, it works properly. Installed Windows 10 again leaving the Windows 7 environment. The installed RC-Assistent then didn't work. Removed Windows 10, installed Windows 7 again and suddenly it was saturday evening :-))))
And under Windows 7 de USB driver installed well and RC-assistent also worked properly.
Hmmm spoke too soon. All downloads on laptop running windows 8.1 with Mcafee but don't seem to be able to connect and give me the blue light. Dug my old windows 7 laptop out that has no security and is only used for storing pictures.
Running sweet as. Configured, calabrated & updated. Not sure which part of the change has made it work !
Going out for its maiden voyage tomorrow if it's not too wet & windy.
@Toelis we did indeed. The phantom came back in one piece, having only one battery meant our outing wasn't very long but it was good fun. Have some great first pics and videos. Def investing in a couple more batteries.
good to hear
someone says that is a defect in win 10, it is not , it is security as old apps are often trouble...
but now you see what is was doing, it is higher level security that stops a lot of the old issues.
change is good,
frustrating at times but look at that new toy your playing with...
mrf00xy
